PRETBOLT
I/O Options and Subcase Information Entry The PRETBOLT command can be used in the I/O Options or Subcase Information sections to request output of pretension force/adjustment values in the pretension bolts for all pretensioning and pretensioned subcases.
PRETBOLT (format) = option
Argument | Options | Description |
format | <OPTI, blank> |
option | <YES, NO> |
PRETBOLT (OPTI) = YES
PRETBOLT = NO
PRETBOLT (OPTI)
PRETBOLT
- When a PRETBOLT command is not present, pretension force/adjustment values are not output.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- PRETBOLT(OPTI)=YES can be defined in conjunction with NLOUT Bulk Data and Subcase Entries, to output on-the-fly pretension output to the .pret file.
