PROPERTY
I/O Options and Subcase Information Entry The PROPERTY command can be used in the I/O Options section to request the output of the property definitions used in the final iteration of an optimization.
PROPERTY = option
Argument Options Description
option <FILE, OUT, BOTH, NONE>
Default = FILE
FILE or blank
Updated property definitions are output to the .prop file.
OUT
Updated property definitions are output to the .out file.
BOTH
Updated property definitions are output to both the .out file and the .prop file.
NONE
Updated property definitions are not output.
