PSEC
Bulk Data Entry Defines property information for planar section elements used in the definition of arbitrary beam cross-sections.
PSEC PID MID T
PSEC 5 100 0.1
PID Property identification number.
No default (Integer > 0)
MID Material definition identification number.
T Thickness.
No default (Real > 0.0)
  1. All property identification numbers within a section definition must be unique with respect to all other property identification numbers within the same section definition.
  2. This entry is only valid when it appears between the BEGIN and END statements.
