PSURF
Bulk Data Entry Defines properties of a contact surface.
PSURF | PID | EDGECRIT |
PID | Property
EDGECRIT | Activate edges on the
surface that have feature angle greater than or equal to the
specified value. No default (0.0 ≤ Real ≤ 180.0) |
- This property can be referenced on the CONTACT Bulk Data Entry.
