PTFORC1
Bulk Data Entry Defines pretensioning force on a set of pretension sections.
PTFORC1 PSID F SID1 SID2 SID3 SID4 SID5 SID6
  SID7 SID8 SID9 etc.
PTFORC1 3 500.0 1 3 4
PSID Pretensioning load set identification number.
(Integer > 0)
F Pretensioning force applied on this set of sections. (Positive value creates tension). 2
(Real)
SIDi Pretension section identification number.
(Integer > 0)
  1. PTFORC1 can be referred by PTADD or by the PRETENSION command in the subcase directly.
  2. Pretensioning force is actually a pair of forces, applied to the opposite sides of the pretension section. This represents the effect of tightening the nut by a set longitudinal force (which is related to the applied torque).
