PTFORCE
Bulk Data Entry Defines pretensioning force on pretension section.
PTFORCE PSID SID F
PTFORCE 3 5 0.5
PSID Pretensioning load set identification number.
(Integer > 0)
SID Pretension section identification number.
(Integer > 0)
F Pretensioning force applied on this section. (Positive value creates tension). 2
(Real)
  1. PTFORCE can be referred by PTADD or by the PRETENSION command in the subcase directly.
  2. Pretensioning force is actually a pair of forces, applied to the opposite sides of the pretension section. This represents the effect of tightening the nut by a set longitudinal force (which is related to the applied torque).
