PVISC
Bulk Data Entry Defines properties of a one-dimensional viscous damping element (CVISC entry).
PVISC PID1 CE1 CR1   PID2 CE2 CR2
PVISC 3 6.2 3.94
PID# Property identification number.
No default (Integer > 0)
CE1, CE2 Viscous damping values for extension in units of force per unit velocity.
No default (Real)
CR1, CR2 Viscous damping values for rotation in units of force per unit velocity.
No default (Real)
  1. Viscous properties are material independent; in particular, they are temperature independent.
  2. One or two viscous element properties may be defined on a single entry.
  3. This card is represented as a property in HyperMesh.
