QVOLLIB
Bulk Data Entry Defines the external function called to calculate time and temperature-dependent rate of volumetric heat addition in a conduction element.
QVOLLIB | SID | GROUP | FUNCT |
SID | Load set identification number. No default (Integer > 0) |
GROUP | Defines the shared/dynamic library to be used. Refers to an existing LOADLIB entry in the input deck. No default (Character) |
FUNCT | Defines the external function to be used. No default (Character) |
- The load set identification number (SID) must match the corresponding identification number on the QVOL entry.
