RADPRM, SMDISP
Bulk Data Entry The RADPRM, SMDISP parameter is used to specify if small displacement formulation or large displacement formulation is used.
Parameter | Values | Description |
SMDISP | <0, 1> | When large displacement
effects are negligible, RADPRM,
SMDISP, 1 can be used to
improve the convergence and performance.
