RADSND
Subcase Information Entry The RADSND command can be used to select RADSND Bulk Data to specify sound generation panels and microphone field locations.
RADSND = option
Argument Options Description
option <SID>
Integer > 0
No default
SID
Identification number of RADSND Bulk Data Entry.
  1. Only one RADSND entry can be present in any particular subcase.
  2. If a RADSND entry is present above the first subcase, then it is applied as the default for each applicable subcase.
