Loading [MathJax]/jax/output/CommonHTML/jax.js
RANDPS
Bulk Data Entry Defines load set power spectral density factors for use in random analysis having the frequency dependent form Sjk(Ω)=(X+iY)G(Ω) .
RANDPS SID J K X Y TID
RANDPS 5 3 7 2.0 2.5 4
SID Random analysis set identification number.
(Integer > 0)
J Subcase identification number of excited load set.
(Integer > 0)
K Subcase identification number of applied load set.
(Integer > 0; K ≥ J)
X, Y Components of complex number.
(Real)
TID A TABRNDi entry identification number which defines G(F).
= 0
G(F) = 1.0
Integer ≥ 0
  1. If J = K, then Y must be 0.0.
  2. RANDPS Bulk Data Entries can be referenced either by:
    • The RANDOM Subcase or Case Control Entry.
    • A SET I/O Options Entry that is then referenced by a RANDOM Case Control Entry.
    • A SET Bulk Data Entry with TYPE=MODE that is then referenced by a RANDOM Case Control Entry.
