REPCASE
Subcase Information Entry The REPCASE command can be used to indicate the start of a repeated subcase definition. This is used for multiple output requests of the same type for the same subcase.
REPCASE = integer
Argument | Description |
integer | Repcase identification
number (RID) No default (Integer > 0) |
- Each REPCASE must be declared with a separate REPCASE header and a unique RID.
- REPCASE definitions should immediately follow the subcase that is duplicated. The REPCASE identification numbers should always be greater than the preceding subcase that is being duplicated (and all previous subcases).
- REPCASE is currently supported only for Linear Static Analysis.
- Example REPCASE usage
is displayed below.
SUBCASE 1 SPC = 2 LOAD = 3 DISP(PUNCH)=1 STRESS(PUNCH)=2 REPCASE 2 DISP(PUNCH)=3 STRESS(PUNCH)=4
