RESTARTR
I/O Options EntryDefines the reading requests for nonlinear restart.
RESTARTR = <option> file_prefix
RESTARTR = originaljob_sub5_inc0012
RESTARTR = TERMI, originaljob_sub5_inc0012
RESTARTR = TERMI, D:\tmp\originaljob_sub5_inc0012
Interpretation: the restart model information file to be read is originaljob.rmd and the restart analysis information file to be read is originaljob_sub5_inc0012.rnl. With the prescribing of TERMI, subcase 5 will be truncated after the increment 12.
Argument | Options | Description |
option | TERMI, blank |
file_prefix | Prefix of
.rnl file No default |
Identifies the
.rnl and .rmd files to
be read. The .rnl and .rmd files are named in format <filename>_sub<i>_inc<j>.rnl and <filename>.rmd respectively, where <filename> is the filename of the input deck (prior to .fem), <i> (0<i<100000000) is the corresponding subcase ID and <j> (0<j<10000) is the corresponding increment number in the subcase. |
- If a RESTARTR entry is specified in the model, OptiStruct reads a restart model information file (*.rmd) and a restart analysis information file (*.rnl) to restart a nonlinear analysis run that was interrupted earlier.
- The RESTARTR entry can only be specified outside and above any subcase.
- For information on restart of nonlinear analysis, refer to Restart of Nonlinear Analysis in the User Guide.
- RESTARTW and RESTARTR entries can be specified together, except for the very first run (that is, the original job that is subsequently restarted), where only RESTARTW is allowed.
