RWALADD
Bulk Data Entry Defines a rigid wall set as a union of rigid walls defined via RWALL entries.
RWALADD SID S1 S2 S3 S4 S5 S6 S7
  S8 S9 etc.
RWALADD 101 2 3 1 6 4
SID Set identification number.
(Integer > 0)
Sj Set identification numbers of rigid wall sets defined via RWALL entries. Must be unique and may not be the identification number of a rigid wall set defined by another RWALADD entry.
(Integer > 0)
  1. Multipoint constraint sets must be selected with the Subcase Information command RWALL=SID.
  2. RWALADD entries take precedence over RWALL entries. If both have the same SID, only the RWALADD entry will be used.
  3. This card is represented as a load collector in HyperMesh.
