SEALL
Subcase Information Entry Identifies the Superelements for Generation and Assembly for One-Step Superelement Analysis.
SEALL = option
Argument Options Description
option <ALL, SID, or SEID>
ALL (Default)
All superelements are generated and assembled.
SID
SET entry identification number, which lists the superelements for generation and assembly.
SEID
Superelement for generation and assembly identification number.
  1. The SEALL entry should be specified above the first subcase.
  2. All superelements are generated and assembled, if the SEALL entry is not present.
