SECSET1
Bulk Data Entry Defines free boundary degrees-of-freedom to be free for use in One-Step Superelement Analysis (Alternate Format).
SECSET1 SEID C G1 G2 G3 G4 G5 G6
  G7 G8 etc
Alternate Format
SECSET1 SEID C G1 THRU G2
SECSET1 12 346 3 33 1 55 67 893
  12 982
SEID Superelement identification number.
No default (Integer ≥ 0)
C Component numbers.
(Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.)
Gi Grid or Scalar Point identification numbers.
Default = Blank (Integer > 0, or THRU)
  1. If THRU option is used, then G1 should be less than G2.
