SECSET
Bulk Data Entry Defines free boundary degrees-of-freedom for One-Step Superelement Analysis.
SECSET SEID G1 C G2 C G3 C
SECSET 11 23 6 8 12 511 33
SEID Superelement identification number.
No default (Integer ≥ 0)
Gi Grid or Scalar Point identification numbers .
Default = Blank (Integer > 0)
Ci Component numbers.
(Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.)
  1. Degrees-of-freedom on SECSET entry are used to define the boundary degrees-of-freedom which are to be free (C-Set).
