SENSITIVITY
I/O Options and Subcase Information Entry The SENSITIVITY command can be used in the I/O Options section to request the output of the responses and sensitivities for size and shape design variables to a Microsoft Excel spreadsheet.
SENSITIVITY = option
Argument | Options | Description |
option | <YES,
NO, ALL, NONE,
STRESS, NOSTRESS> Default = NONE |
- This command is ignored when OUTPUT, MSSENS command is present.
- The frequency of this output is controlled by the SENSOUT option.
- For more details on the output format, refer to #.slk file.
- Additional sensitivity output requests for topology, free-sizing and gauge design variables can be made through OUTPUT and OUTPUT (in H3D format), and OUTPUT (ASCII format).
