SEQSET1
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis (Alternate Format).
SEQSET1 | SEID | C | G1 | G2 | G3 | G4 | G5 | G6 | |
G7 | G8 | etc |
Alternate Format
SEQSET1 | SEID | C | G1 | THRU | G2 |
SEQSET1 | 12 | 123456 | 2 | 45 | 923 | 1344 | 3 | 922 | |
23 | 26 |
SEID | Superelement
identification number. No default (Integer ≥ 0) |
C | Component
numbers. Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points. |
Gi | Grid or Scalar Point
identification numbers (should be an external point). Default = Blank (Integer > 0, or THRU) |
- Degrees-of-freedom on SEQSET entry should not be used on any other Superelement.
- If the THRU option is used, then G1 should be less than G2.
