Bulk Data Entry Defines the interior grid points for One-Step
Superelement Analysis.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SESET |
SEID |
G1 |
G2 |
G3 |
G4 |
G5 |
G6 |
G7 |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SESET |
SEID |
G1 |
THRU |
G2 |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
SESET |
4 |
333 |
12 |
556 |
99 |
5 |
Field |
Contents |
SI Unit Example |
SEID |
Superelement
identification number. No default (Integer ≥ 0)
Gi |
Grid or Scalar Point
identification numbers. Default = Blank (Integer > 0, or
THRU)
- Grid point entries via
Gi should not be repeated on the SESET
entry.
- If the THRU option
is used, then G1 should always be less than
G2.
