SET1
Bulk Data Entry Defines a list of structural grid points or element identification numbers.
SET1 | SID | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | |
ID8 | etc. |
Example 1
SET1 | 3 | 31 | 62 | 93 | 124 | 16 | 17 | 18 | |
19 |
Example 2
SET1 | 6 | 29 | 32 | THRU | 50 | 61 | THRU | 70 | |
17 | 57 |
SID | Unique identification number. (Integer > 0) |
IDi | List
of structural grid point or element identification
numbers. (Integer > 0 or "THRU, ENDTHRU, and EXCEPT"; for the "THRU" option, ID1 < ID2) |
