SET3
Bulk Data Entry Defines a set of grids or elements.
SET3 SID TYPE ID1 ID2 ID3 ID4 ID5 ID6
  ID7 ID8 etc.
Example 1
SET3 1 PROP 11 12 13 15 18 21
Alternate Format and Example
SET3 SID TYPE ID1 "THRU" ID2
SET3 33 GRID 20 THRU 60
SID Unique identification number.
(Integer > 0)
TYPE Set type.
GRID
Grid points.
ELEM
Elements.
PROP
Creates a list of elements associated with the property ID's listed.
(Character)
IDi Identifiers of grid points, elements, or properties.
(Integer > 0)
  1. All set ID's must be unique for all Bulk Data SET, SET1, SET3, and solution control SET data.
  2. The use of keywords THRU, ENDTHRU, and EXCEPT are allowed.
  3. This card is represented as a set in HyperMesh.
