SETREE
Bulk Data Entry Defines the Superelement Tree for One-Step Superelement Analysis.
SETREE | SEID | SEUP1 | SEUP2 | SEUP3 | SEUP4 | SEUP5 | SEUP6 | SEUP7 | |
SEUP8 | SEUP9 | etc |
SETREE | 7 | 333 | 12 | 556 | 99 | 5 |
SEID | Superelement
identification number. No default (Integer ≥ 0) |
SEUPi | Superelements upstream of
SEID identification numbers. Default = Blank (Integer > 0) |
- SEUPi fields should be unique across all SETREE entries.
