SHRES
I/O Options EntryThe SHRES command can be used in the I/O Options section to control the frequency of output of the state files (.#.sh file and the .#.grid file).
SHRES = frequency
Argument | Options | Description |
frequency | <FIRST, LAST,
FL, ALL,
NONE, N> Default = LAST |
- When a SHRES command is not present, state files are output for the final iteration only.
- The .grid file is only output for shape, topography, and free-shape optimization.
- For all .sh and .grid output files bar the last one, the files are named <prefix><iter#>.sh(.grid). The last one is just named <prefix>.sh(.grid).
- The .grid file output may also be controlled by the GRID keyword on the OUTPUT card.
- From 10.0 onwards, it is recommended to use the OUTPUT I/O Option Entry to control this output.
