Specialized Result Outputs
Keyword | Description | Default Frequency | Affected Files | Options | Details |
ADAMSMNF | Output of flexible body to a modal neutral file for MSC.ADAMS. 17 | - | *.mnf | <YES,
NO> Default = YES |
HGFREQ | Frequency Analysis output presentation for HyperGraph. 3 | FL | *_freq.mvw, *_s#_a.frf, *_s#_d.frf, *_s#_v.frf |
HGTRANS | Transient Analysis output presentation for HyperGraph. 2 3 28 | - | *_tran.mvw, *_s#_a.trn, *_s#_d.trn, *_s#_s.trn, *_s#_v.trn |
HGMBD | - | *_mbd.mvw, *_s#_a.mbd, *_s#_d.mbd, *_s#_v.mbd |
HGEFFMASS | Effective mass is output as a HyperGraph bar chart via the BAR option (default), or as a HyperGraph XY plot via XY option. | - | *.mass,
*_mass.mvw |
HGMODFAC | Modal participation factor output presentation for HyperGraph 3D. 14 | FL | *_modal.mvw, *_modal.#.mvw |
<REGULAR, NORM> Default = REGULAR |
MASSPROP | Controls the output of Center of Gravity and Mass Moments of Inertia tables based on properties to .out file. 20 | FL | *.out | - | The center of gravity is specified in the basic coordinate system. The Mass Properties are with respect to the center of gravity of the item. |
MASSCOMP | Controls the output of mass based on HyperMesh components to the .out file. | FL | *.out | - | - |
REGCOMPL | Controls the output of regional compliance table to .out file. | *.out | <YES,
NO> Default = YES |
24 | |
KPI | Controls the output of Key Performance Indicators to .kpi file (ASCII). | FL | *.kpi | - | |
MATRIX | Controls the output of Stiffness, Mass, and Grid-to-DOF mapping matrices to .full.mat and .reduced.mat files (ASCII). | - | *.reduced.mat,
*.full.mat |
Option
1: <FULL, REDUCED> No default Option 2: <DENSE, SPARSE> Default = DENSE |
The FULL and
REDUCED options control whether the full or
reduced stiffness/mass matrices are output to the
.full.mat and
.reduced.mat
ASCII files. An additional optional control, DENSE and SPARSE allows control over whether to output the fully dense matrices or to only output the sparse matrices (without zeros). |
PCOMP | Output equivalent PCOMPG from the ply-based modeling (STACK/PCOMPP) input. | - | *.pcomp | - | This is supported for analysis and optimization. The Frequency option is not supported for this keyword. |
