SPL
I/O Options and Subcase Information Entry The SPL command can be used in the I/O Options or Subcase Information sections to request Sound Pressure output for all subcases or individual subcases, respectively. SPL can only be requested for frequency response subcases.
SPL = option
Argument | Options | Description |
format | <H3D, PUNCH, blank> | |
option | <ALL> Default = ALL |
- When the SPL command is present, Sound Pressure is output for all microphone grids for all frequency response subcases.
- The Punch file format for
SPL results is:
Format GID G Real/Mag Sound Pressure Imag/Phase Sound Pressure Sound Pressure Level Example 9252 G 1.943054E+06 3.226665E+02 1.257697E+02
