SPLINE2
Bulk Data Entry Defines a beam spline for interpolating motion and/or forces for aeroelastic problems on aerodynamic geometries defined by regular arrays of aerodynamic points.
SPLINE2 | EID | CAERO | ID1 | ID2 | SETG | DZ | DTOR | CID | |
DTHX | DTHY | USAGE |
SPLINE2 | 57 | 32 | 12 | 13 | 11 | 0.0 | 1.0 | 4 | |
1.0 |
EID | Unique spline identification number. (Integer > 0) |
CAERO | Aero-element (CAEROi entry ID) that is to
be interpolated. (Integer > 0) |
BOX1, BOX2 | First and last box whose motions are interpolated using this
spline. 6
(Integer > 0; ID2 > ID1) |
SETG | Refers to the SETi entry that lists the
structural grid points to which the spline is attached.
(Integer > 0) |
DZ | Linear attachment flexibility. Default = 0.0 (Real ≥ 0.0) |
DTOR | Torsional flexibility ratio (EI/GJ). Default = 1.0 (Real > 0.0, use 1.0 for bodies) |
CID | Rectangular coordinate system for which the Y-axis defines
the axis of the spline. Not used for bodies,
CAERO2. (Integer ≥ 0) |
DTHX, DTHY | Rotational attachment flexibility.
(Real ≥ 0) |
USAGE | Spline usage flag. 8
- The interpolated points (k-set) will be defined by aero boxes.
- The spline axis for panels is the projection of the y-axis of coordinate system CID, projected onto the plane of the panel.
- The flexibilities DZ, DTHX, and DTHY are used for smoothing. (Zero attachment flexibility values will imply rigid attachment; i.e., no smoothing).
- The continuation line is required.
- The SPLINE2 EID must be unique with respect to all SPLINEi entries.
- DTOR is the ratio of rotational to linear deflection and, in lieu of a more accurate estimate, a value of 1.0 is recommended. A different value may be used; e.g., if DTOR is much greater than 1.0, primarily rotational deflection will occur; if DTOR is much less than 1.0, primarily linear deflection will occur.
- If a SPLINE2 element only references one grid point, the job will fail without a message.
- The USAGE field allows you to specify that the particular spline interpolant defined in this entry is to be used for both the force transformation and the displacement transformation. Currently, only the BOTH option is supported for the USAGE field.
