SUBCASE
Subcase Information Entry The SUBCASE command can be used to indicate the start of a new subcase definition.
SUBCASE = integer
Argument | Description |
integer | Subcase identification
number (SID). No default (Integer > 0) |
- Each subcase must be declared with a separate SUBCASE header and a unique SID.
- The SUBCASE header is not needed, if there is just one subcase.
