SUPORT1
Subcase Information Entry The SUPORT1 command can be used to select a fictitious support set to be applied to the model.
SUPORT1 = option
Argument Options Description
option <SID>
No default
SID
Identification number of a support set via a SUPORT1 Bulk Data Entry.
  1. SUPORT1 Bulk Data Entries will be used only if selected in the Subcase Information section by the SUPORT1 Subcase Information Entry.
  2. The SUPORT1 Bulk Data Entry selected by the SUPORT1 Subcase Information Entry will be applied in all subcases.
