SWLDPRM, PROJTOL
Bulk Data Entry Tolerance to accept the projected points (from GS for CWELD and from GS/GE for CSEAM) if the computed coordinates of the projection point lies outside the shell element but is located within PROJTOLx (dimension of the shell element).
Parameter | Values | Description |
PROJTOL | 0.0 < Real <
0.5 Default = 0.05 |
PROJTOL is only activated when a search without PROJTOL finds no candidate shell to build connectivity for a connector element. This prevents the search from picking the wrong shell element in cases when PROJTOL is not needed. |
