SWLDPRM, SHOWAUX
Bulk Data Entry Output fictitious grids representing auxiliary points generated for CWELD and fictitious hexa corner points generated for CSEAM into a file which can be directly imported into HyperMesh to visualize the connector elements.
Parameter | Values | Description |
SHOWAUX | <YES, 1,
NO, 0> Default = NO |
For clarity of
visualization, this file also includes the eight-node
CHEXA elements with corners at respective
auxiliary points for CWELD or at respective
fictitious hexa corner points for
CSEAM. For each CWELD element, this data will only be output in cases where no error is issued before the definition of auxiliary points. For the CSEAM element, this data will only be output if all seam elements are built successfully. For CWELD, the root file name will be followed with .weldaux.fem. For
CSEAM, the root file name will be
followed with .seamaux.fem.
