TABLED1
Bulk Data Entry Defines a tabular function for use in generating frequency-dependent and time-dependent dynamic loads.
TABLED1 | TID | XAXIS | YAXIS | FLAT | |||||
x1 | y1 | x2 | y2 | x3 | y3 | x4 | y4 | ||
x5 | y5 | etc. | etc. | etc. | etc. | etc. | etc. |
TABLED1 | 32 | ||||||||
-3.0 | 6.9 | 2.0 | 5.6 | 3.0 | 5.6 | ENDT |
TID | Table identification
number. No default (Integer > 0) |
XAXIS | Specifies a linear or
logarithmic interpolation for the x-axis. 5
YAXIS | Specifies a linear or
logarithmic interpolation for the y-axis. 5
FLAT | Specifies the handling
method for y-values outside the specified range of x-values in the
table.
x#, y# | Tabular values. Any x, y pair may be ignored by placing SKIP in either of the two fields used for that entry. No default (Real or ENDT) |
- xi must be in either ascending or descending order, but not both.
- For example, in Figure 1 discontinuities are allowed only between points x2 through x7 . Also, if y is evaluated at a discontinuity, the average value of y is used. In Figure 1, the value of y at x=x3 is y=(y3+y4)/2 .
- At least one continuation entry must be specified.
- The end of the table is indicated by the existence of ENDT in either of the two fields following the last entry. An error is detected if any continuations follow the entry containing the end-of-table flag ENDT.
- For
FLAT=0 (default),
TABLED1 uses the algorithm:
(1) y=yT(x)Where,- x
- Input to the table
- y
- Is returned
The table look-up is performed using interpolation within the table and linear extrapolation outside the table using the two starting or end points (Figure 1). The algorithms used for interpolation or extrapolation are:X-Axis Y-Axis yT(x) Linear Linear xj−xxj−xiyi+x−xixj−xiyj Log Linear ln(xj/x)ln(xj/xi)yi+ln(x/xi)ln(xj/xi)yj Linear Log exp[xj−xxj−xiln yi+x−xixj−xiln yj] Log Log exp[ln(xj/x)ln(xj/xi)ln yi+ln(x/xi)ln(xj/xi)ln yj] Where, xj and yj follow xi and yi .
No warning messages are issued if table data is input incorrectly.
Figure 1. Example of Table Extrapolation and DiscontinuityFor FLAT=1, the same algorithm as FLAT=0 is used, except that values outside the range are not extrapolated. The corresponding start or end point y-values are used for all y-values outside the range.
- Linear extrapolation is not used for Fourier transform methods. The function is zero outside the range of the table.
- For frequency-dependent loads, x# is measured in cycles per unit time.
- Tabular values on an axis if X-Axis or Y-Axis=LOG must be positive. A fatal message will be issued if an axis has a tabular value ≤ 0.
- This card is represented as a load collector in HyperMesh.
