TABLEG
Bulk Data Entry Defines a general tabular function for use in supported reference entries.
TABLEG TID LABEL TYPE XYTYPE FLAT
  x1 y1
  x2 y2
  etc. etc.
TABLEG 32
  -3.0 6.9
  2.0 5.6
TID Table identification number.
No default (Integer > 0)
LABEL Specify a name or label for the table
Default = blank (<string> or blank)
TYPE Specifies a linear or logarithmic interpolation for the x-axis and y-axis. 4
LINEAR (Default)
LOG
XYTYPE Specifies how the X-axis and Y-axis are interpreted
XY (Default)
First column is the X-axis and the second column is the Y-axis
YX
First column is the Y-axis and the second column is the X-axis
FLAT Specifies the handling method for y-values outside the specified range of x-values in the table.
= 0 (Default)
If an x-value input is outside the range of x-values specified on the table, the corresponding y-value look-up is performed using linear extrapolation from the two starting or two ending points.
= 1
If an x-value input is outside the lower limit or upper limit of x-values specified on the table, the corresponding y-value is equal to the value at the starting or ending point, respectively.
x#, y# Tabular values.
No default (Real)
  1. xi MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaamyAaaaa@3AC2@ must be in either ascending or descending order, but not both.
  2. Discontinuities may be specified between any two points except the two starting points or two end points. Also, if y MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4baaaa@39D4@ is evaluated at a discontinuity, the average value of y MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4baaaa@39D4@ is used. In Figure 1, the value of y MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4baaaa@39D4@ at x=x3 MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaeyypa0JaamiEaiaaiodaaaa@3C94@ is y MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4baaaa@39D4@ = ( y=(y3+y4)/2 MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG5bGaeyypa0ZaaeWaaeaacaWG5bGaaG4maiabgUcaRiaadMhacaaI0aaacaGLOaGaayzkaaGaai4laiaaikdaaaa@422C@ .
  3. At least one continuation entry must be specified.
  4. TABLEG uses the algorithm:(1)
    y=yT(x)
    Where,
    x MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4baaaa@39D4@
    Input to the table
    Is returned
    The table look-up is performed using interpolation within the table and linear extrapolation outside the table using the two starting or end points (Figure 1). The algorithms used for interpolation or extrapolation are:
    X-Axis Y-Axis yT(x)
    Linear Linear xjxxjxiyi+xxixjxiyj
    Log Log exp[ln(xj/x)ln(xj/xi)lnyi+ln(x/xi)ln(xj/xi)lnyj]
    Where, xj MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaamOAaaaa@3AC3@ and yj MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaamOAaaaa@3AC3@ follow xi MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaamOAaaaa@3AC3@ and yi MathType@MTEF@5@5@+=feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKfMBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhiov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaakeaacaWG4bGaamOAaaaa@3AC3@ .
    No warning messages are issued if table data is input incorrectly.
    Figure 1. Example of Table Extrapolation and Discontinuity
  5. Linear extrapolation is not used for Fourier transform methods. The function is zero outside the range of the table.
  6. For frequency-dependent loads, x# is measured in cycles per unit time.
  7. Tabular values on an axis if TYPE =LOG must be positive. A fatal message will be issued if an axis has a tabular value ≤ 0.
  8. TABLEG can be used in the following situations:
    • TABLEG can be used instead of TABLED1, on the RLOAD and TLOAD Bulk Data Entries.
    • TABLEG can be used instead of TABLEM1, on the MATT# entries.
    • TABLEG can be used instead of TABLES1, on the MATS1 or PCONT entries.
  9. TABLEG identification numbers should be unique with regard to any other TABLE# entry. TABLEG should not have the same ID as any other TABLE# entry.
  10. If there are any unused TABLEG entries in the input file, there will not be any warning in the .out file.
