Bulk Data Entry Defines a tabular function for Stress (X) - Life (Y)
pairs to define an SN curve.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
TABLEXN
TID
TYPE
x1
y1
x2
y2
x3
y3
x4
y4
x5
y5
etc.
etc.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
TABLEXN
32
SN
1.0
6.9
2.0
5.6
3.0
5.6
ENDT
Field
Contents
SI Unit Example
TID
Table identification
number.
No default (Integer > 0)
TYPE
Specifies the type of
curve.
=SN
Identifies the table as an SN curve.
No default
x#,
y#
Tabular values.
No
default (Real or ENDT)
xi must be in either
ascending or descending order, but not both.
Discontinuities between any two points
except the two starting points or two end points. For example, in Figure 1 discontinuities are allowed only between points x2 through x7. Also, if y is evaluated at a discontinuity, the average
value of y is used. In Figure 1, the value of y at x=x3 is
y=(y3+y4)/2.
At least one continuation entry must be
specified.
Any x, y pair may be ignored by placing
SKIP in either of the two fields used for that entry.
The end of the table is indicated by the
existence of ENDT in either of the two fields following the last
entry. An error is detected if any continuations follow the entry containing the
end-of-table flag ENDT.
TABLEXN uses the
algorithm:(1)
y=yT(x)
Where,
x
Input to the table
y
Is returned
The table look-up is performed using interpolation within the
table and linear extrapolation outside the table using the two starting or
end points (Figure 1). The algorithms used for interpolation or extrapolation
is:(2)
yT(x)=xj−xxj−xiyi+x−xixj−xiyj
Where, xj and yj follow xi and yi. Figure 1. Example of Table Extrapolation and
Discontinuity
TABLEXN can be
directly selected via the MCRV_ID field on the
MATFAT entry or referenced on the TIDi
fields of the FATMCRV entry.
