TEMP
Bulk Data Entry Defines temperature at grid points or a SET of grid points for determination of Thermal Loading and Stress recovery.
TEMP SID G/
GSETID
T G T G T
  GSET
TEMP 3 94 316.2 49 219.8
SID LOAD set identification.
(Integer > 0)
G/GSETID This field represents a grid point identification number, or if the GSET continuation line is specified, an identification number of a SET of grid points.
(Integer > 0)
T Temperature.
(Real)
GSET Flag which indicates that the G/GSETID field is identified as a SET of grid points, at which the temperatures are applied.
  1. Temperature sets may be selected for use in a subcase by the TEMPERATURE or TEMPERATURE(BOTH) Subcase Information Entry. For transient heat transfer analysis, the temperature set can be selected by IC Subcase Information Entry to specify initial condition.
  2. From one to three grid point temperatures may be defined on a single entry. If GSET continuation line is present, then the referenced SET can consist of any number of grid points.
  3. This card is represented as a temperature load in HyperMesh.
