TEMPD
Bulk Data Entry Defines a temperature value for all grid points of the structural model that have not been given a temperature on a TEMP entry.
TEMPD SID T SID T SID T SID T
TEMPD 1 216.3
SID LOAD set identification.
(Integer > 0)
T Default temperature value. From one to four default temperatures may be defined on a single entry.
(Real)
  1. Temperature sets may be selected for use in a subcase by the TEMPERATURE or TEMPERATURE(BOTH) Subcase Information Entry. For transient heat transfer analysis, the temperature set can be selected by IC Subcase Information Entry to specify initial condition.
  2. This card is represented as a load collector in HyperMesh.
