The thickness mapping feature allows the user to map the thickness data from an
external forming result file to the corresponding model in OptiStruct.
Consider a situation, when a component obtained from sheet metal forming needs to be
analyzed further in an assembly model, after accounting for the thickness variation
from forming.
Examples of such scenarios include stamping of an automotive door panel using
HyperForm, followed by a full vehicle durability
analysis using OptiStruct. In such cases, the thickness
mapping featured in OptiStruct, can be used. Figure 1. Thickness Mapping Feature Overview
Note:
In the OptiStruct model file, an initial
thickness needs to be defined and the thickness mapping feature will
overwrite a new thickness distribution for the elements specified in the
thickness mapping definition.
The thickness mapping feature works even when the following attributes
are different between the forming result file and the OptiStruct model file:
Mesh – Element types, Element ID, Node ID, Element order
Orientation of the components being mapped (in the presence of
relocation)
Problem Setup Example
The following example of the thickness mapping process in an input
file.
$ USING ASSIGN TO REFERENCE THE FORMING RESULT FILE
ASSIGN, MAP, 100,"forming_result.k"
$ REQUESTING THICKNESS OUTPUT FOR VISUALIZATION
THICKNESS(CORNER)=ALL
BEGIN BULK
$ DEFINITION OF MAP ENTRY
MAP, 1, THICK, 12, 100
$ SET OF ELEMENTS TO WHICH THE MAPPING MUST BE APPLIED
SET, 12, ELEM, LIST
+, ALL
Figure 2 shows mapping across dissimilar
mesh types. Figure 2. (a) Forming result file from which thickness data needs to be
mapped; (b) OptiStruct model file to which the
thickness data is mapped
