THIN
I/O Options and Subcase Information Entry The THIN command can be used in the I/O Options or Subcase Information sections to request thinning and thickness output for all geometric nonlinear analysis subcases or individual geometric nonlinear analysis subcases, respectively.
THIN (format, type) = option
Argument Options Description
format <H3D, blank>
H3D
Results are output in Hyper3D format (.h3d file).
blank (Default)
Results are output in all active formats for which the result is available.
type <ALL, THIN, THICK>
ALL (Default)
Thinning and thickness results are output.
THIN
Percentage element thinning only is output.
THICK
Element thickness only is output.
option <YES, ALL, NO, NONE, SID, PSID>
Default = ALL
YES, ALL, blank
Thinning/thickness are output for all elements.
NO, NONE
Thinning/thickness are not output.
SID
If a set ID is given, thinning/thickness are output only for elements listed in that set.
PSID
If a property set ID is given, thinning/thickness results for the elements referencing properties listed in the property set are output.
  1. THIN is only applicable for geometric nonlinear analysis subcases which are defined by an ANALYSIS = NLGEOM subcase entry.
  2. Only formats that have been activated by an OUTPUT statement are valid for use on this card.
  3. Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
  4. Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
