The cyclical pattern grouping allows you to force OptiStruct to create a series of symmetric shape variables about a
central axis that repeat a number of times determined by you (with the
UCYC field).
This can be useful in assigning a reinforcement pattern in a circular plate that matches an
angularly repeated load in a symmetric fashion.
For cyclical pattern groupings (TYP=40 and
41), OptiStruct generates a series
of symmetric shape variables about an axis defined by the cross product of the first
and second vectors. The axis of rotation is positioned at the anchor point. The
first vector defines a plane establishing one side of the cyclical wedge. The other
side of the cyclical wedge is defined by the angle of repetition. Figure 1 shows cyclical pattern grouping for
three "wedges". Figure 1. TYP=40: Cyclical Pattern Grouping for 3 Repetitions
OptiStruct allows any number of repeated cyclical wedges by entering
the number of desired wedges into field 30 (UCYC). OptiStruct internally calculates the repetition angle
according to the formula 360.0/UCYC. For example, setting
UCYC to three results in three wedges of 120.0 each, and
setting UCYC to 6 results in six wedges of 60.0 each.
You can also control whether the cyclical repetitions will be symmetric within themselves. This
is done by choosing one of the cyclical TYP options ending in
'1' (41, 51,
61, 71, and 81). If the
symmetric wedge option is selected, OptiStruct will
force each wedge to be symmetric about its centerline. Selecting one of the cyclical
options ending in '0' (40, 50,
60, 70, and 80) will result
in the wedges being non-symmetric (Figure 2 and Figure 3). Figure 2. TYP=40 (non-symmetric) with UCYC=5 Figure 3. TYP=41 (symmetric) with UCYC=3
Other Forms of Cyclical Pattern Grouping
OptiStruct supports the combination of cyclical pattern grouping with
one plane symmetry, linear pattern grouping, radial pattern grouping, and radial
linear pattern grouping. Each option is specified with a different base
TYP number to which the number denoting the repetition angle
is added.
For one plane cyclical pattern grouping (TYP=50 and
51), the cyclical patterns are reflected about a plane located
at the anchor node and defined by the cross product of the first and second vectors.
One plane cyclical symmetry ensures that nodes equal distances above and below the
plane of symmetry will be grouped into the same variables (Figure 4). Figure 4. TYP=50: One Plane Cyclical Symmetry with 3 Wedges
For linear cyclical symmetry (TYP=60 and
61), OptiStruct generates shape
variables that run along a line parallel to the cross product of the first and
second vectors. These shape variables have a width equal to the minimum bead width
parameter but have no limit on length. The full lengths of the linearly drawn shape
variables will be cyclically symmetric: Figure 5. TYP=60: Linear Cyclical Pattern Grouping with 3 Wedges
For radial cyclical pattern grouping (TYP=70 and
71), OptiStruct generates shape
variables that run radially away from a central axis defined by the cross product of
the first and second vector. Radial beads have a width equal to the minimum bead
width parameter but have no limit on length. The width of the beads does not change
depending on the distance from the center. The full lengths of the radially drawn
shape variables will be cyclically symmetric: Figure 6. TYP=70: Radial Cyclical Pattern Grouping with 3 Wedges
For radial linear cyclical pattern grouping (TYP=80 and
81), OptiStruct generates a series
of planes that run radially away from and in the same plane as the first vector. The
radial linear cyclical pattern grouping is essentially the linear cyclical pattern
grouping combined with the radial pattern grouping. The full lengths of the radially
drawn shape variables will be cyclically symmetric.
