Linear pattern grouping allows you to force OptiStruct to create beads in a
given direction along the entire length of the part.
This can be very useful for optimizing the shape of extruded parts which must maintain a constant
cross section. It is also very useful when
optimizing the side walls of stamped plates whose
beads must run from the top to the bottom so that
the part can be drawn from the die. In solid
models, where the variable needs to control the
movement of all grids through the thickness,
linear pattern grouping is also very useful.
For linear pattern grouping (TYP=1, 21, or
31), OptiStruct generates shape
variables that run along a line parallel to the
first vector. These shape variables have a width
equal to the minimum bead width parameter but have
no limit on length. For simple linear pattern
grouping, the anchor point and first vector can be
located anywhere. Figure 1. TYP=1: Linear Pattern Grouping
For one and two plane linear symmetry, the anchor point locates the plane(s) of symmetry. For one
(TYP=21), the
second vector defines the symmetry plane (since
the first vector has been used to define the
direction of the pattern). Figure 2. TYP=21: One Plane Linear Symmetry
For two plane symmetry (TYP=31), the symmetry planes are
defined by the second vector and the cross product
of the first and second vectors (Figure 3). There
is no three plane linear pattern grouping since
the pattern is automatically symmetric in the
direction of the first vector. Figure 3. TYP=31: Two Plane Linear Symmetry
