_tran.mvw file
The _tran.mvw file is a HyperView session file.
File Creation
This file is only created when a transient response analysis is performed. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
This file is a HyperView session file and may be opened from the File menu in HyperView or HyperGraph. The file automatically creates plots for each of the results contained in the _s#_a.trn file, _s#_d.trn, and _s#_v.trn file.
