TRIM
Subcase Information Entry Used to select trim variable constraints by referencing a corresponding TRIM Bulk Data Entry.
TRIM = option
Argument | Options | Description |
option | <ID> No default |
- Aerodynamic extra points (trim variables) not constrained by a TRIM Bulk Data Entry will be free during the static aeroelastic response solution.
