TSTEP
Subcase Information Entry The TSTEP command can be used to select integration for transient analysis.
TSTEP (type) = option
TSTEP = 731T
STEP (FOURIER) = 755
Argument | Options | Description |
type | <TIME, FOURIER> |
option | <SID> No default |
- A TSTEP entry must be selected to execute a transient analysis. TSTEP(FOURIER) is supported in both Direct and Modal Transient Analysis. Transient Response Analysis using Fourier Transformation via TSTEP(FOURIER) cannot be used in a model which also contains a Modal Frequency Response Analysis subcase. OptiStruct will error out in such cases.
- A TSTEP entry can also be used to execute a transient thermal analysis (only for type=TIME or default).
- For the application of time-dependent loads in modal frequency response analysis, a TSTEP Bulk Data Entry must be selected by the TSTEP(FOURIER) command. The time-dependent loads will be recomputed in the frequency domain by a Fourier transform.
