TTERM
I/O Options and Subcase Information Entry The TTERM command can be used to define the termination time.
TTERM = value
Argument | Description |
value | Termination time for
Nonlinear Explicit Analysis (NLEXPL) or Explicit Dynamic Analysis
(EXPDYN) subcase. Default = 1.0 (Real) |
- TTERM is only allowed in Nonlinear Explicit Analysis (NLEXPL) and Explicit Dynamic Analysis subcases which are defined by an ANALYSIS= EXPDYN or ANALYSIS= EXPDYN subcase entries.
- Nonlinear Explicit Analysis (NLEXPL) is the OptiStruct Explicit solution, and Explicit Dynamic Analysis (EXPDYN) is the Explicit solution based on OptiStruct-Radioss Integration (Bulk to Block translation).
