XDAMP
Bulk Data Entry Defines the values for Raleigh damping for geometric nonlinear dynamic analysis.
XDAMP | DID | GSID | ALFA | BETA |
XDAMP | 100 | 34 | 3.0 | 1.0 |
DID | Unique damping
identification number. (Integer ˃ 0) |
GSID | Grid set identification
number. Damping is applied to the grid points in this set. Default = all grids in the model (blank or Integer ˃ 0) |
ALFA | Factor for the stiffness
matrix contribution. (Real ˃ 0) |
BETA | Factor for the mass matrix
- Rayleigh damping is applied to all geometric nonlinear dynamic analysis subcases, implicit and explicit. It is ignored in all other subcases.
- In implicit dynamic analysis damping is applied to all grid points and GSID is ignored. Multiple XDAMP is not allowed in implicit dynamic analysis.
- XDAMP and PARAM W3/G are mutually exclusive.
- Grid sets in all XDAMP statements must contain unique sets of grid points.
- The viscous damping matrix
B is calculated from the mass matrix M and
stiffness matrix K using:
(1) - This card is represented as an interface in HyperMesh.
