XHISADD
Bulk Data Entry Defines a time history output set as a union of time history outputs defined via XHIST entries.
XHISADD SID S1 S2 S3 S4 S5 S6 S7
  S8 S9 etc.
XHISADD 101 2 3 1 6 4
SID Set identification number.
(Integer ˃ 0)
Sj Set identification numbers of time history output defined via XHIST entries. Must be unique and may not be the identification number of a rigid wall set defined by another XHISADD entry.
(Integer ˃ 0)
  1. Multipoint constraint sets must be selected with the Subcase Information command XHIST=SID.
  2. XHISADD entries take precedence over XHIST entries. If both have the same SID, only the XHISADD entry will be used.
  3. This card is represented as a load collector in HyperMesh.
