Create and Delete Elements
Use the Edit: Create tool to create new 1D, 2D tria, or 2D quad elements, and delete elements.
Edit: Create Tool
An overview of the Edit: Create tool.
Figure 3.
- Access
- Go to .
Options
- Intersections >
- Set intersection tolerance to find out penetration level of two intersecting elements.
- Face angles <
- Set dihedral angle to find out sharp angle elements.
- Element organization
- Select the component in which elements are placed.
