Define Gap Based Refinement Criteria
Use the Gap tool to define mesh refinement settings based on gaps between surfaces.
Select the surfaces on which to apply the mesh
control in the following ways:
- While in the Mesh ribbon, select two or more surfaces, then right-click and select from the context menu.
- From the Mesh ribbon, click the
Gap tool.
Figure 1.Select surfaces.
- In the dialog, define gap refinement options.
From the guide bar, execute the command in the following
ways:
- Click
to confirm your selection and remain in the tool.
This allows you to continue creating instances and helps you visualize and edit instances with the legend.
- Click
to confirm your selection and exit the tool.
- Click
