Create Channels
Create or import channels (load histories).
Add Time Data Loads
Add Constant Amplitude Loads
Add Block Loads
Block loads are available for the Time Series loading type.
- Use the
and
icons to import and export block load .csv files.
- Select a block and click
to delete it.
- To exclude a block from the load, deactivate its checkbox.
