Other Methods for Fitting a Curve The following methods require certain parameters other than UTS to define the SN/EN curve. From the Assign Material dialog, click the My Material tab and select your created material. Select an input method. Click to view the model description. Define any necessary parameters. Note: The images below use the default values as a guideline. SN Properties Figure 1. Point, 1-seg Figure 2. Point, 2-seg Figure 3. Slope-intcept, 1-seg Figure 4. Slope-intcept, 2-seg Figure 5. Slope-trans, 1-seg Figure 6. Slope-trans, 2-seg EN Properties Figure 7. Slope
